Time Before: 0.00205 seconds
Time After: 0.00286 seconds
Time Taken: 0.00081 seconds
Time Before: 0.00297 seconds
Time After: 0.00342 seconds
Time Before: 0.00367 seconds
Time After: 0.00385 seconds
Time Before: 0.00475 seconds
Time After: 0.00737 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00393 seconds
Time After: 0.01224 seconds
Time Taken: 0.00831 seconds
Time Before: 0.01465 seconds
Time After: 0.01525 seconds
Time Taken: 0.00060 seconds
Time Before: 0.01899 seconds
Time After: 0.02024 seconds
Time Before: 0.01389 seconds
Time After: 0.02045 seconds
Time Taken: 0.00656 seconds
Time Before: 0.02662 seconds
Time After: 0.02677 seconds
Time Before: 0.03062 seconds
Time After: 0.03186 seconds
End call of global.php: 0.034457921981812
Time Before: 0.03605 seconds
Time After: 0.03643 seconds
Time Before: 0.03946 seconds
Time After: 0.04099 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=141497', badlocation = 1
Time Before: 0.05866 seconds
Time After: 0.05896 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.057492017745972 seconds with 9 queries, spending 0.008716344833374 doing MySQL queries and 0.048775672912598 doing PHP things.
