Time Before: 0.01632 seconds
Time After: 0.02122 seconds
Time Taken: 0.00490 seconds
Time Before: 0.02131 seconds
Time After: 0.02172 seconds
Time Before: 0.02196 seconds
Time After: 0.02219 seconds
Time Before: 0.02328 seconds
Time After: 0.02607 seconds
Time Taken: 0.00278 seconds
Time Before: 0.02225 seconds
Time After: 0.03166 seconds
Time Taken: 0.00941 seconds
Time Before: 0.04111 seconds
Time After: 0.04157 seconds
Time Before: 0.04424 seconds
Time After: 0.04544 seconds
Time Before: 0.04019 seconds
Time After: 0.04562 seconds
Time Taken: 0.00543 seconds
Time Before: 0.08192 seconds
Time After: 0.08206 seconds
Time Before: 0.29317 seconds
Time After: 0.29459 seconds
End call of global.php: 0.29693698883057
Time Before: 0.30269 seconds
Time After: 0.30286 seconds
Time Before: 0.30605 seconds
Time After: 0.30764 seconds
Time Taken: 0.00160 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=141511', badlocation = 1
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.32634 seconds
Time After: 0.32663 seconds
Page generated in 0.32524991035461 seconds with 9 queries, spending 0.0086987018585205 doing MySQL queries and 0.31655120849609 doing PHP things.
