Time Before: 0.02274 seconds
Time After: 0.02895 seconds
Time Taken: 0.00621 seconds
Time Before: 0.02902 seconds
Time After: 0.02944 seconds
Time Before: 0.02966 seconds
Time After: 0.02981 seconds
Time Before: 0.03051 seconds
Time After: 0.03279 seconds
Time Taken: 0.00228 seconds
Time Before: 0.02989 seconds
Time After: 0.03693 seconds
Time Taken: 0.00704 seconds
Time Before: 0.04590 seconds
Time After: 0.04632 seconds
Time Before: 0.04887 seconds
Time After: 0.05017 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04529 seconds
Time After: 0.05042 seconds
Time Taken: 0.00513 seconds
Memory After: 2,261.820 KB
Time Before: 0.09163 seconds
Time After: 0.09178 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 1.12396 seconds
Time After: 1.12636 seconds
Time Taken: 0.00241 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 1.13541 seconds
Time After: 1.13557 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 1.13892 seconds
Time After: 1.14151 seconds
Time Taken: 0.00259 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788970552, location = '/forums/private.php?do=newpm&explain=1&u=141513' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 1.15890 seconds
Time After: 1.15930 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
