Time Before: 0.00155 seconds
Time After: 0.00213 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00220 seconds
Time After: 0.00272 seconds
Time Before: 0.00293 seconds
Time After: 0.00303 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00369 seconds
Time After: 0.00643 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00308 seconds
Time After: 0.00982 seconds
Time Taken: 0.00674 seconds
Time Before: 0.01221 seconds
Time After: 0.01260 seconds
Time Before: 0.01480 seconds
Time After: 0.01599 seconds
Time Before: 0.01163 seconds
Time After: 0.01617 seconds
Time Taken: 0.00454 seconds
Time Before: 0.02116 seconds
Time After: 0.02128 seconds
Time Before: 0.02386 seconds
Time After: 0.02513 seconds
End call of global.php: 0.027052164077759
Time Before: 0.02840 seconds
Time After: 0.02854 seconds
Time Before: 0.03066 seconds
Time After: 0.03212 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=141529'
WHERE sessionhash = 'aed90e65d11e22ea884774a0c30a33f2'
Time Before: 0.04688 seconds
Time After: 0.04710 seconds
Page generated in 0.045945167541504 seconds with 9 queries, spending 0.0081641674041748 doing MySQL queries and 0.037781000137329 doing PHP things.
