Time Before: 0.01763 seconds
Time After: 0.02570 seconds
Time Taken: 0.00807 seconds
Time Before: 0.02578 seconds
Time After: 0.02622 seconds
Time Before: 0.02651 seconds
Time After: 0.02667 seconds
Time Before: 0.02749 seconds
Time After: 0.03009 seconds
Time Taken: 0.00259 seconds
Time Before: 0.02676 seconds
Time After: 0.03428 seconds
Time Taken: 0.00752 seconds
Time Before: 0.04128 seconds
Time After: 0.04172 seconds
Time Before: 0.04486 seconds
Time After: 0.04612 seconds
Time Before: 0.04050 seconds
Time After: 0.04635 seconds
Time Taken: 0.00586 seconds
Time Before: 0.08662 seconds
Time After: 0.08681 seconds
Time Before: 0.10456 seconds
Time After: 0.10580 seconds
End call of global.php: 0.10802102088928
Time Before: 0.11416 seconds
Time After: 0.11433 seconds
Time Before: 0.11787 seconds
Time After: 0.12003 seconds
Time Taken: 0.00216 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=14159', badlocation = 1
Time Before: 0.14056 seconds
Time After: 0.14092 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
Page generated in 0.13931608200073 seconds with 9 queries, spending 0.0090405941009521 doing MySQL queries and 0.13027548789978 doing PHP things.
