Time Before: 0.00134 seconds
Time After: 0.00181 seconds
Time Before: 0.00191 seconds
Time After: 0.00241 seconds
Time Before: 0.00282 seconds
Time After: 0.00300 seconds
Time Before: 0.00394 seconds
Time After: 0.00713 seconds
Time Taken: 0.00319 seconds
Time Before: 0.00308 seconds
Time After: 0.01056 seconds
Time Taken: 0.00748 seconds
Time Before: 0.01243 seconds
Time After: 0.01263 seconds
Time Before: 0.01517 seconds
Time After: 0.01643 seconds
Time Before: 0.01183 seconds
Time After: 0.01660 seconds
Time Taken: 0.00477 seconds
Time Before: 0.02281 seconds
Time After: 0.02305 seconds
Time Before: 0.02503 seconds
Time After: 0.02629 seconds
End call of global.php: 0.027898073196411
Time Before: 0.02904 seconds
Time After: 0.02921 seconds
Time Before: 0.03131 seconds
Time After: 0.03278 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=141613', badlocation = 1
Time Before: 0.04518 seconds
Time After: 0.04545 seconds
Page generated in 0.044286966323853 seconds with 9 queries, spending 0.0087392330169678 doing MySQL queries and 0.035547733306885 doing PHP things.
