Time Before: 0.02120 seconds
Time After: 0.02857 seconds
Time Taken: 0.00737 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02866 seconds
Time After: 0.02907 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02931 seconds
Time After: 0.02945 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03031 seconds
Time After: 0.03250 seconds
Time Taken: 0.00219 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02952 seconds
Time After: 0.03659 seconds
Time Taken: 0.00707 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04376 seconds
Time After: 0.04414 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04688 seconds
Time After: 0.04810 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04297 seconds
Time After: 0.04832 seconds
Time Taken: 0.00535 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.08584 seconds
Time After: 0.08601 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.86670 seconds
Time After: 0.86826 seconds
Time Taken: 0.00156 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.87056112289429
Time Before: 0.89488 seconds
Time After: 0.89504 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.90084 seconds
Time After: 0.90233 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1772912844, location = '/forums/private.php?do=newpm&explain=1&u=141614', badlocation = 1
WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.92753 seconds
Time After: 0.92781 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.92654800415039 seconds with 9 queries, spending 0.0079989433288574 doing MySQL queries and 0.91854906082153 doing PHP things.
