Time Before: 0.01266 seconds
Time After: 0.01766 seconds
Time Taken: 0.00500 seconds
Time Before: 0.01776 seconds
Time After: 0.01820 seconds
Time Before: 0.01847 seconds
Time After: 0.01862 seconds
Time Before: 0.01944 seconds
Time After: 0.02205 seconds
Time Taken: 0.00261 seconds
Time Before: 0.01869 seconds
Time After: 0.02630 seconds
Time Taken: 0.00761 seconds
Time Before: 0.03243 seconds
Time After: 0.03288 seconds
Time Before: 0.03429 seconds
Time After: 0.03548 seconds
Time Before: 0.03163 seconds
Time After: 0.03568 seconds
Time Taken: 0.00406 seconds
Time Before: 0.05676 seconds
Time After: 0.05693 seconds
Time Before: 0.06600 seconds
Time After: 0.06769 seconds
Time Taken: 0.00169 seconds
End call of global.php: 0.07011604309082
Time Before: 0.07687 seconds
Time After: 0.07703 seconds
Time Before: 0.08003 seconds
Time After: 0.08155 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=141668', badlocation = 1
Time Before: 0.09732 seconds
Time After: 0.09762 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
Page generated in 0.096293210983276 seconds with 9 queries, spending 0.0086801052093506 doing MySQL queries and 0.087613105773926 doing PHP things.
