Time Before: 0.01911 seconds
Time After: 0.02367 seconds
Time Taken: 0.00455 seconds
Time Before: 0.02376 seconds
Time After: 0.02423 seconds
Time Before: 0.02463 seconds
Time After: 0.02476 seconds
Time Before: 0.02554 seconds
Time After: 0.02783 seconds
Time Taken: 0.00229 seconds
Time Before: 0.02482 seconds
Time After: 0.03203 seconds
Time Taken: 0.00721 seconds
Time Before: 0.03843 seconds
Time After: 0.03882 seconds
Time Before: 0.04155 seconds
Time After: 0.04278 seconds
Time Before: 0.03762 seconds
Time After: 0.04301 seconds
Time Taken: 0.00539 seconds
Time Before: 0.07393 seconds
Time After: 0.07406 seconds
Time Before: 0.08747 seconds
Time After: 0.08870 seconds
End call of global.php: 0.090862989425659
Time Before: 0.09778 seconds
Time After: 0.09793 seconds
Time Before: 0.10038 seconds
Time After: 0.10182 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=141688', badlocation = 1
WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.11896 seconds
Time After: 0.11924 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.11797213554382 seconds with 9 queries, spending 0.0077419281005859 doing MySQL queries and 0.11023020744324 doing PHP things.
