Time Before: 0.01979 seconds
Time After: 0.02782 seconds
Time Taken: 0.00804 seconds
Time Before: 0.02793 seconds
Time After: 0.02833 seconds
Time Before: 0.02852 seconds
Time After: 0.02863 seconds
Time Before: 0.02937 seconds
Time After: 0.03159 seconds
Time Taken: 0.00222 seconds
Time Before: 0.02870 seconds
Time After: 0.03593 seconds
Time Taken: 0.00723 seconds
Time Before: 0.04833 seconds
Time After: 0.04860 seconds
Time Before: 0.05100 seconds
Time After: 0.05222 seconds
Time Before: 0.04750 seconds
Time After: 0.05246 seconds
Time Taken: 0.00496 seconds
Time Before: 0.07361 seconds
Time After: 0.07374 seconds
Time Before: 0.27417 seconds
Time After: 0.27538 seconds
End call of global.php: 0.277498960495
Time Before: 0.28697 seconds
Time After: 0.28718 seconds
Time Before: 0.28975 seconds
Time After: 0.29121 seconds
SET lastactivity = 1783149155, location = '/forums/private.php?do=newpm&explain=1&u=141743', badlocation = 1
Time Before: 0.31115 seconds
Time After: 0.31142 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.31010389328003 seconds with 9 queries, spending 0.0074784755706787 doing MySQL queries and 0.30262541770935 doing PHP things.
