Time Before: 0.00942 seconds
Time After: 0.01191 seconds
Time Taken: 0.00250 seconds
Time Before: 0.01199 seconds
Time After: 0.01244 seconds
Time Before: 0.01269 seconds
Time After: 0.01281 seconds
Time Before: 0.01368 seconds
Time After: 0.01635 seconds
Time Taken: 0.00267 seconds
Time Before: 0.01287 seconds
Time After: 0.02040 seconds
Time Taken: 0.00752 seconds
Time Before: 0.02480 seconds
Time After: 0.02522 seconds
Time Before: 0.02842 seconds
Time After: 0.02963 seconds
Time Before: 0.02411 seconds
Time After: 0.02984 seconds
Time Taken: 0.00572 seconds
Time Before: 0.05576 seconds
Time After: 0.05594 seconds
Time Before: 0.06237 seconds
Time After: 0.06369 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.066017866134644
Time Before: 0.06937 seconds
Time After: 0.06953 seconds
Time Before: 0.07245 seconds
Time After: 0.07388 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=141760'
Time Before: 0.08973 seconds
Time After: 0.09001 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.088806867599487 seconds with 9 queries, spending 0.0082459449768066 doing MySQL queries and 0.080560922622681 doing PHP things.
