Time Before: 0.00686 seconds
Time After: 0.00749 seconds
Time Taken: 0.00063 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00757 seconds
Time After: 0.00795 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00816 seconds
Time After: 0.00837 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00927 seconds
Time After: 0.01222 seconds
Time Taken: 0.00295 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00845 seconds
Time After: 0.01642 seconds
Time Taken: 0.00797 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01869 seconds
Time After: 0.01911 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.02166 seconds
Time After: 0.02452 seconds
Time Taken: 0.00286 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.01811 seconds
Time After: 0.02471 seconds
Time Taken: 0.00660 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.03209 seconds
Time After: 0.03223 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.04419 seconds
Time After: 0.04590 seconds
Time Taken: 0.00172 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.048337936401367
Time Before: 0.06203 seconds
Time After: 0.06266 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.06701 seconds
Time After: 0.06885 seconds
Time Taken: 0.00184 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1765017593, location = '/forums/private.php?do=newpm&explain=1&u=141783', badlocation = 1
WHERE sessionhash = '2677c8ed1972db23ee529da3b6169906'
Time Before: 0.09446 seconds
Time After: 0.09472 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.093246936798096 seconds with 9 queries, spending 0.011415958404541 doing MySQL queries and 0.081830978393555 doing PHP things.
