Time Before: 0.00146 seconds
Time After: 0.00211 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00217 seconds
Time After: 0.00266 seconds
Time Before: 0.00293 seconds
Time After: 0.00310 seconds
Time Before: 0.00394 seconds
Time After: 0.00691 seconds
Time Taken: 0.00297 seconds
Time Before: 0.00317 seconds
Time After: 0.01048 seconds
Time Taken: 0.00731 seconds
Time Before: 0.01231 seconds
Time After: 0.01274 seconds
Time Before: 0.01545 seconds
Time After: 0.01670 seconds
Time Before: 0.01165 seconds
Time After: 0.01688 seconds
Time Taken: 0.00523 seconds
Time Before: 0.02167 seconds
Time After: 0.02184 seconds
Time Before: 0.02394 seconds
Time After: 0.02522 seconds
End call of global.php: 0.026828050613403
Time Before: 0.02796 seconds
Time After: 0.02812 seconds
Time Before: 0.03001 seconds
Time After: 0.03143 seconds
SET lastactivity = 1789145503, location = '/forums/private.php?do=newpm&explain=1&u=141797', badlocation = 1
Time Before: 0.04393 seconds
Time After: 0.04417 seconds
Page generated in 0.043015956878662 seconds with 9 queries, spending 0.0085659027099609 doing MySQL queries and 0.034450054168701 doing PHP things.
