Time Before: 0.00993 seconds
Time After: 0.01399 seconds
Time Taken: 0.00406 seconds
Time Before: 0.01412 seconds
Time After: 0.01453 seconds
Time Before: 0.01476 seconds
Time After: 0.01489 seconds
Time Before: 0.01594 seconds
Time After: 0.01885 seconds
Time Taken: 0.00290 seconds
Time Before: 0.01496 seconds
Time After: 0.02343 seconds
Time Taken: 0.00847 seconds
Time Before: 0.03067 seconds
Time After: 0.03112 seconds
Time Before: 0.03257 seconds
Time After: 0.03383 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03000 seconds
Time After: 0.03406 seconds
Memory After: 2,261.820 KB
Time Before: 0.05189 seconds
Time After: 0.05203 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.06631 seconds
Time After: 0.06765 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.07667 seconds
Time After: 0.07687 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.07972 seconds
Time After: 0.08120 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788982237, location = '/forums/private.php?do=newpm&explain=1&u=141845' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.10174 seconds
Time After: 0.10230 seconds
Time Taken: 0.00056 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
