Time Before: 0.00148 seconds
Time After: 0.00199 seconds
Time Before: 0.00224 seconds
Time After: 0.00273 seconds
Time Before: 0.00299 seconds
Time After: 0.00313 seconds
Time Before: 0.00379 seconds
Time After: 0.00737 seconds
Time Taken: 0.00358 seconds
Time Before: 0.00318 seconds
Time After: 0.01074 seconds
Time Taken: 0.00756 seconds
Time Before: 0.01268 seconds
Time After: 0.01307 seconds
Time Before: 0.01448 seconds
Time After: 0.01595 seconds
Time Before: 0.01213 seconds
Time After: 0.01613 seconds
Time Taken: 0.00401 seconds
Time Before: 0.02327 seconds
Time After: 0.02353 seconds
Time Before: 0.02550 seconds
Time After: 0.02671 seconds
End call of global.php: 0.028416156768799
Time Before: 0.02955 seconds
Time After: 0.02972 seconds
Time Before: 0.03175 seconds
Time After: 0.03334 seconds
Time Taken: 0.00159 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=141861', badlocation = 1
Time Before: 0.04977 seconds
Time After: 0.05002 seconds
Page generated in 0.048855066299438 seconds with 9 queries, spending 0.0095500946044922 doing MySQL queries and 0.039304971694946 doing PHP things.
