Time Before: 0.00165 seconds
Time After: 0.00277 seconds
Time Taken: 0.00112 seconds
Time Before: 0.00284 seconds
Time After: 0.00323 seconds
Time Before: 0.00341 seconds
Time After: 0.00353 seconds
Time Before: 0.00418 seconds
Time After: 0.00632 seconds
Time Taken: 0.00214 seconds
Time Before: 0.00358 seconds
Time After: 0.01152 seconds
Time Taken: 0.00794 seconds
Time Before: 0.01468 seconds
Time After: 0.01485 seconds
Time Before: 0.01731 seconds
Time After: 0.01871 seconds
Time Before: 0.01400 seconds
Time After: 0.01902 seconds
Time Taken: 0.00503 seconds
Time Before: 0.02675 seconds
Time After: 0.02687 seconds
Time Before: 1.37153 seconds
Time After: 1.37309 seconds
Time Taken: 0.00156 seconds
End call of global.php: 1.375253200531
Time Before: 1.37826 seconds
Time After: 1.37839 seconds
Time Before: 1.38082 seconds
Time After: 1.38223 seconds
SET lastactivity = 1776685789, location = '/forums/private.php?do=newpm&explain=1&u=141866', badlocation = 1
Time Before: 1.39904 seconds
Time After: 1.39935 seconds
Page generated in 1.3979461193085 seconds with 9 queries, spending 0.0077672004699707 doing MySQL queries and 1.3901789188385 doing PHP things.
