Time Before: 0.00913 seconds
Time After: 0.01142 seconds
Time Taken: 0.00229 seconds
Time Before: 0.01152 seconds
Time After: 0.01197 seconds
Time Before: 0.01227 seconds
Time After: 0.01240 seconds
Time Before: 0.01322 seconds
Time After: 0.01577 seconds
Time Taken: 0.00255 seconds
Time Before: 0.01251 seconds
Time After: 0.02013 seconds
Time Taken: 0.00762 seconds
Time Before: 0.02489 seconds
Time After: 0.02533 seconds
Time Before: 0.02847 seconds
Time After: 0.03098 seconds
Time Taken: 0.00251 seconds
Time Before: 0.02422 seconds
Time After: 0.03120 seconds
Time Taken: 0.00698 seconds
Time Before: 0.05711 seconds
Time After: 0.05726 seconds
Time Before: 0.06550 seconds
Time After: 0.06679 seconds
End call of global.php: 0.06923508644104
Time Before: 0.07390 seconds
Time After: 0.07409 seconds
Time Before: 0.07737 seconds
Time After: 0.07932 seconds
Time Taken: 0.00195 seconds
SET lastactivity = 1780612992, location = '/forums/private.php?do=newpm&explain=1&u=141873', badlocation = 1
WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.09588 seconds
Time After: 0.09612 seconds
Page generated in 0.094892978668213 seconds with 9 queries, spending 0.009913444519043 doing MySQL queries and 0.08497953414917 doing PHP things.
