Time Before: 0.00139 seconds
Time After: 0.00203 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00210 seconds
Time After: 0.00281 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00307 seconds
Time After: 0.00330 seconds
Time Before: 0.00401 seconds
Time After: 0.00643 seconds
Time Taken: 0.00243 seconds
Time Before: 0.00335 seconds
Time After: 0.00979 seconds
Time Taken: 0.00643 seconds
Time Before: 0.01175 seconds
Time After: 0.01210 seconds
Time Before: 0.01451 seconds
Time After: 0.01573 seconds
Time Before: 0.01111 seconds
Time After: 0.01591 seconds
Time Taken: 0.00479 seconds
Time Before: 0.02092 seconds
Time After: 0.02109 seconds
Time Before: 0.02306 seconds
Time After: 0.02439 seconds
Time Taken: 0.00133 seconds
Time Before: 0.02740 seconds
Time After: 0.02760 seconds
Time Before: 0.02953 seconds
Time After: 0.03096 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=141881', badlocation = 1 WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.04334 seconds
Time After: 0.04358 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
