Time Before: 0.01488 seconds
Time After: 0.01961 seconds
Time Taken: 0.00472 seconds
Time Before: 0.01968 seconds
Time After: 0.02039 seconds
Time Taken: 0.00071 seconds
Time Before: 0.02088 seconds
Time After: 0.02099 seconds
Time Before: 0.02166 seconds
Time After: 0.02387 seconds
Time Taken: 0.00221 seconds
Time Before: 0.02104 seconds
Time After: 0.02759 seconds
Time Taken: 0.00655 seconds
Time Before: 0.03238 seconds
Time After: 0.03275 seconds
Time Before: 0.03521 seconds
Time After: 0.03638 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03179 seconds
Time After: 0.03656 seconds
Time Taken: 0.00478 seconds
Time Before: 0.05977 seconds
Time After: 0.05989 seconds
Time Before: 0.07374 seconds
Time After: 0.07500 seconds
End call of global.php: 0.076833963394165
Time Before: 0.08495 seconds
Time After: 0.08512 seconds
Time Before: 0.08755 seconds
Time After: 0.08979 seconds
Time Taken: 0.00224 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=14193', badlocation = 1
WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.10931 seconds
Time After: 0.10964 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.10791277885437 seconds with 9 queries, spending 0.0086960792541504 doing MySQL queries and 0.09921669960022 doing PHP things.
