Time Before: 0.01804 seconds
Time After: 0.02728 seconds
Time Taken: 0.00924 seconds
Time Before: 0.02738 seconds
Time After: 0.02785 seconds
Time Before: 0.02811 seconds
Time After: 0.02823 seconds
Time Before: 0.02902 seconds
Time After: 0.03171 seconds
Time Taken: 0.00269 seconds
Time Before: 0.02830 seconds
Time After: 0.03539 seconds
Time Taken: 0.00710 seconds
Time Before: 0.04453 seconds
Time After: 0.04488 seconds
Time Before: 0.04740 seconds
Time After: 0.04866 seconds
Time Before: 0.04388 seconds
Time After: 0.04890 seconds
Time Taken: 0.00502 seconds
Time Before: 0.08894 seconds
Time After: 0.08911 seconds
Time Before: 0.10997 seconds
Time After: 0.11123 seconds
End call of global.php: 0.11341404914856
Time Before: 0.12171 seconds
Time After: 0.12186 seconds
Time Before: 0.12450 seconds
Time After: 0.12599 seconds
SET lastactivity = 1785408366, location = '/forums/private.php?do=newpm&explain=1&u=141975', badlocation = 1
Time Before: 0.14701 seconds
Time After: 0.14735 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.1459379196167 seconds with 9 queries, spending 0.0083022117614746 doing MySQL queries and 0.13763570785522 doing PHP things.
