Time Before: 0.00209 seconds
Time After: 0.00258 seconds
Time Before: 0.00268 seconds
Time After: 0.00322 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00349 seconds
Time After: 0.00366 seconds
Time Before: 0.00452 seconds
Time After: 0.00675 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00374 seconds
Time After: 0.01197 seconds
Time Taken: 0.00824 seconds
Time Before: 0.01435 seconds
Time After: 0.01483 seconds
Time Before: 0.01770 seconds
Time After: 0.01895 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01366 seconds
Time After: 0.01921 seconds
Time Taken: 0.00555 seconds
Memory After: 2,261.820 KB
Time Before: 0.02475 seconds
Time After: 0.02492 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"39.32,\";s:9:\"lastcheck\";i:1789026812;}', 1)
Time Before: 0.03137 seconds
Time After: 0.03171 seconds
Memory Before: 2,816.633 KB
Memory After: 2,816.883 KB
Memory Used: 0.250 KB
Time Before: 0.03414 seconds
Time After: 0.03539 seconds
Memory Before: 2,903.938 KB
Memory After: 2,904.531 KB
End call of global.php: 0.037804126739502
Time Before: 0.03951 seconds
Time After: 0.03966 seconds
Memory Before: 3,540.688 KB
Memory After: 3,541.117 KB
Time Before: 0.04270 seconds
Time After: 0.04418 seconds
Memory Before: 3,822.422 KB
Memory After: 3,824.109 KB
SET lastactivity = 1789026812, location = '/forums/private.php?do=newpm&explain=1&u=142036'
Time Before: 0.05973 seconds
Time After: 0.06007 seconds
Memory Before: 4,296.156 KB
Memory After: 4,296.383 KB
Page generated in 0.05859899520874 seconds with 10 queries, spending 0.0084025859832764 doing MySQL queries and 0.050196409225464 doing PHP things.
