Time Before: 0.01019 seconds
Time After: 0.01439 seconds
Time Taken: 0.00421 seconds
Time Before: 0.01456 seconds
Time After: 0.01516 seconds
Time Taken: 0.00060 seconds
Time Before: 0.01548 seconds
Time After: 0.01564 seconds
Time Before: 0.01637 seconds
Time After: 0.01856 seconds
Time Taken: 0.00219 seconds
Time Before: 0.01571 seconds
Time After: 0.02257 seconds
Time Taken: 0.00685 seconds
Time Before: 0.02782 seconds
Time After: 0.02824 seconds
Time Before: 0.03071 seconds
Time After: 0.03204 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02711 seconds
Time After: 0.03227 seconds
Time Taken: 0.00515 seconds
Memory After: 2,261.836 KB
Time Before: 0.05342 seconds
Time After: 0.05356 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.06740 seconds
Time After: 0.06867 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.070756912231445
Time Before: 0.07443 seconds
Time After: 0.07459 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.07685 seconds
Time After: 0.07829 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788902503, location = '/forums/private.php?do=newpm&explain=1&u=14211', badlocation = 1
Time Before: 0.09691 seconds
Time After: 0.09731 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.095878839492798 seconds with 9 queries, spending 0.0081117153167725 doing MySQL queries and 0.087767124176025 doing PHP things.
