Time Before: 0.02061 seconds
Time After: 0.02783 seconds
Time Taken: 0.00722 seconds
Time Before: 0.02795 seconds
Time After: 0.02841 seconds
Time Before: 0.02867 seconds
Time After: 0.02882 seconds
Time Before: 0.02970 seconds
Time After: 0.03208 seconds
Time Taken: 0.00238 seconds
Time Before: 0.02890 seconds
Time After: 0.03800 seconds
Time Taken: 0.00910 seconds
Time Before: 0.04569 seconds
Time After: 0.04615 seconds
Time Before: 0.04772 seconds
Time After: 0.04891 seconds
Time Before: 0.04493 seconds
Time After: 0.04910 seconds
Time Taken: 0.00417 seconds
Time Before: 0.08486 seconds
Time After: 0.08501 seconds
Time Before: 0.10745 seconds
Time After: 0.10884 seconds
Time Taken: 0.00139 seconds
Time Before: 0.12306 seconds
Time After: 0.12324 seconds
Time Before: 0.12676 seconds
Time After: 0.12824 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=142166' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.14775 seconds
Time After: 0.14822 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
