Time Before: 0.00187 seconds
Time After: 0.00252 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00262 seconds
Time After: 0.00305 seconds
Time Before: 0.00337 seconds
Time After: 0.00349 seconds
Time Before: 0.00442 seconds
Time After: 0.00752 seconds
Time Taken: 0.00310 seconds
Time Before: 0.00356 seconds
Time After: 0.01179 seconds
Time Taken: 0.00823 seconds
Time Before: 0.01417 seconds
Time After: 0.01457 seconds
Time Before: 0.01705 seconds
Time After: 0.01831 seconds
Time Before: 0.01338 seconds
Time After: 0.01855 seconds
Time Taken: 0.00517 seconds
Time Before: 0.02577 seconds
Time After: 0.02591 seconds
Time Before: 0.02819 seconds
Time After: 0.02945 seconds
End call of global.php: 0.032076835632324
Time Before: 0.03357 seconds
Time After: 0.03375 seconds
Time Before: 0.03674 seconds
Time After: 0.03824 seconds
SET lastactivity = 1783106361, location = '/forums/private.php?do=newpm&explain=1&u=142177'
Time Before: 0.05335 seconds
Time After: 0.05364 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.052176952362061 seconds with 9 queries, spending 0.0086925029754639 doing MySQL queries and 0.043484449386597 doing PHP things.
