Time Before: 0.01367 seconds
Time After: 0.01903 seconds
Time Taken: 0.00536 seconds
Time Before: 0.01910 seconds
Time After: 0.01956 seconds
Time Before: 0.01989 seconds
Time After: 0.02003 seconds
Time Before: 0.02093 seconds
Time After: 0.02344 seconds
Time Taken: 0.00251 seconds
Time Before: 0.02009 seconds
Time After: 0.02838 seconds
Time Taken: 0.00828 seconds
Time Before: 0.03450 seconds
Time After: 0.03501 seconds
Time Before: 0.03830 seconds
Time After: 0.03953 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03376 seconds
Time After: 0.03970 seconds
Time Taken: 0.00594 seconds
Memory After: 2,261.703 KB
Time Before: 0.05967 seconds
Time After: 0.05981 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.07069 seconds
Time After: 0.07192 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.07850 seconds
Time After: 0.07864 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.08089 seconds
Time After: 0.08302 seconds
Time Taken: 0.00213 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=142180' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.10102 seconds
Time After: 0.10152 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
