Time Before: 0.00897 seconds
Time After: 0.01233 seconds
Time Taken: 0.00336 seconds
Time Before: 0.01243 seconds
Time After: 0.01288 seconds
Time Before: 0.01310 seconds
Time After: 0.01324 seconds
Time Before: 0.01399 seconds
Time After: 0.01669 seconds
Time Taken: 0.00270 seconds
Time Before: 0.01329 seconds
Time After: 0.02128 seconds
Time Taken: 0.00799 seconds
Time Before: 0.02563 seconds
Time After: 0.02609 seconds
Time Before: 0.02850 seconds
Time After: 0.02970 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02489 seconds
Time After: 0.02992 seconds
Time Taken: 0.00503 seconds
Memory After: 2,261.703 KB
Time Before: 0.05634 seconds
Time After: 0.05685 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 3.22853 seconds
Time After: 3.23062 seconds
Time Taken: 0.00210 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 3.24149 seconds
Time After: 3.24169 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 3.24428 seconds
Time After: 3.24581 seconds
Time Taken: 0.00153 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=142300', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 3.26248 seconds
Time After: 3.26280 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
