Time Before: 0.00138 seconds
Time After: 0.00189 seconds
Time Before: 0.00195 seconds
Time After: 0.00264 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00291 seconds
Time After: 0.00305 seconds
Time Before: 0.00373 seconds
Time After: 0.00639 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00310 seconds
Time After: 0.01145 seconds
Time Taken: 0.00836 seconds
Time Before: 0.01387 seconds
Time After: 0.01431 seconds
Time Before: 0.01726 seconds
Time After: 0.01855 seconds
Time Before: 0.01314 seconds
Time After: 0.01886 seconds
Time Taken: 0.00572 seconds
Time Before: 0.02570 seconds
Time After: 0.02587 seconds
Time Before: 0.02808 seconds
Time After: 0.02937 seconds
Time Before: 0.03230 seconds
Time After: 0.03245 seconds
Time Before: 0.03456 seconds
Time After: 0.03602 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=142302' WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.04888 seconds
Time After: 0.04920 seconds
