Time Before: 0.02081 seconds
Time After: 0.02918 seconds
Time Taken: 0.00838 seconds
Time Before: 0.02930 seconds
Time After: 0.02996 seconds
Time Taken: 0.00067 seconds
Time Before: 0.03033 seconds
Time After: 0.03050 seconds
Time Before: 0.03132 seconds
Time After: 0.03404 seconds
Time Taken: 0.00273 seconds
Time Before: 0.03058 seconds
Time After: 0.03834 seconds
Time Taken: 0.00776 seconds
Time Before: 0.04497 seconds
Time After: 0.04535 seconds
Time Before: 0.04767 seconds
Time After: 0.04895 seconds
Time Before: 0.04419 seconds
Time After: 0.04917 seconds
Time Taken: 0.00498 seconds
Time Before: 0.08344 seconds
Time After: 0.08366 seconds
Time Before: 0.10159 seconds
Time After: 0.10290 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.10577392578125
Time Before: 0.11237 seconds
Time After: 0.11255 seconds
Time Before: 0.11529 seconds
Time After: 0.11676 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=142310'
Time Before: 0.13552 seconds
Time After: 0.14448 seconds
Time Taken: 0.00895 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.13437390327454 seconds with 9 queries, spending 0.017342329025269 doing MySQL queries and 0.11703157424927 doing PHP things.
