Time Before: 0.02565 seconds
Time After: 0.03181 seconds
Time Taken: 0.00617 seconds
Time Before: 0.03193 seconds
Time After: 0.03254 seconds
Time Taken: 0.00061 seconds
Time Before: 0.03285 seconds
Time After: 0.03594 seconds
Time Taken: 0.00309 seconds
Time Before: 0.03701 seconds
Time After: 0.04102 seconds
Time Taken: 0.00400 seconds
Time Before: 0.03601 seconds
Time After: 0.04603 seconds
Time Taken: 0.01003 seconds
Time Before: 0.05633 seconds
Time After: 0.05661 seconds
Time Before: 0.05794 seconds
Time After: 0.05922 seconds
Time Before: 0.05515 seconds
Time After: 0.05945 seconds
Time Taken: 0.00430 seconds
Time Before: 0.09550 seconds
Time After: 0.09572 seconds
Time Before: 0.28307 seconds
Time After: 0.28433 seconds
Time Before: 0.29419 seconds
Time After: 0.29439 seconds
Time Before: 0.29692 seconds
Time After: 0.29842 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1789110548, location = '/forums/private.php?do=newpm&explain=1&u=142319' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.31732 seconds
Time After: 0.31761 seconds
