Time Before: 0.00242 seconds
Time After: 0.00302 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00308 seconds
Time After: 0.00357 seconds
Time Before: 0.00379 seconds
Time After: 0.00390 seconds
Time Before: 0.00451 seconds
Time After: 0.00706 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00395 seconds
Time After: 0.01042 seconds
Time Taken: 0.00647 seconds
Time Before: 0.01222 seconds
Time After: 0.01261 seconds
Time Before: 0.01516 seconds
Time After: 0.01663 seconds
Time Before: 0.01169 seconds
Time After: 0.01680 seconds
Time Taken: 0.00511 seconds
Time Before: 0.02365 seconds
Time After: 0.02388 seconds
Time Before: 0.02588 seconds
Time After: 0.02709 seconds
End call of global.php: 0.028767824172974
Time Before: 0.03018 seconds
Time After: 0.03031 seconds
Time Before: 0.03227 seconds
Time After: 0.03371 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=14232'
Time Before: 0.04596 seconds
Time After: 0.04621 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.045073986053467 seconds with 9 queries, spending 0.0082607269287109 doing MySQL queries and 0.036813259124756 doing PHP things.
