Time Before: 0.00172 seconds
Time After: 0.00228 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00235 seconds
Time After: 0.00294 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00323 seconds
Time After: 0.00338 seconds
Time Before: 0.00402 seconds
Time After: 0.00786 seconds
Time Taken: 0.00384 seconds
Time Before: 0.00343 seconds
Time After: 0.01264 seconds
Time Taken: 0.00921 seconds
Time Before: 0.01451 seconds
Time After: 0.01528 seconds
Time Taken: 0.00077 seconds
Time Before: 0.01776 seconds
Time After: 0.01902 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01390 seconds
Time After: 0.01924 seconds
Time Taken: 0.00534 seconds
Memory After: 2,261.820 KB
Time Before: 0.02544 seconds
Time After: 0.02559 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02775 seconds
Time After: 0.02901 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.03277 seconds
Time After: 0.03309 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03593 seconds
Time After: 0.03741 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789128436, location = '/forums/private.php?do=newpm&explain=1&u=142361' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05201 seconds
Time After: 0.05244 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
