Time Before: 0.02036 seconds
Time After: 0.02621 seconds
Time Taken: 0.00585 seconds
Time Before: 0.02630 seconds
Time After: 0.02674 seconds
Time Before: 0.02695 seconds
Time After: 0.02711 seconds
Time Before: 0.02792 seconds
Time After: 0.03010 seconds
Time Taken: 0.00218 seconds
Time Before: 0.02719 seconds
Time After: 0.03445 seconds
Time Taken: 0.00726 seconds
Time Before: 0.04220 seconds
Time After: 0.04251 seconds
Time Before: 0.04399 seconds
Time After: 0.04520 seconds
Time Before: 0.04141 seconds
Time After: 0.04546 seconds
Time Taken: 0.00405 seconds
Time Before: 0.08365 seconds
Time After: 0.08380 seconds
Time Before: 0.22097 seconds
Time After: 0.22219 seconds
Time Before: 0.23064 seconds
Time After: 0.23166 seconds
Time Taken: 0.00102 seconds
Time Before: 0.23412 seconds
Time After: 0.23557 seconds
UPDATE session SET lastactivity = 1783311414, location = '/forums/private.php?do=newpm&explain=1&u=142375', badlocation = 1 WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.25487 seconds
Time After: 0.25512 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
