Time Before: 0.00145 seconds
Time After: 0.00191 seconds
Time Before: 0.00198 seconds
Time After: 0.00244 seconds
Time Before: 0.00264 seconds
Time After: 0.00274 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00338 seconds
Time After: 0.00606 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00279 seconds
Time After: 0.01003 seconds
Time Taken: 0.00724 seconds
Time Before: 0.01185 seconds
Time After: 0.01225 seconds
Time Before: 0.01464 seconds
Time After: 0.01589 seconds
Time Before: 0.01131 seconds
Time After: 0.01608 seconds
Time Taken: 0.00477 seconds
Time Before: 0.02184 seconds
Time After: 0.02207 seconds
Time Before: 0.02406 seconds
Time After: 0.02527 seconds
End call of global.php: 0.026968002319336
Time Before: 0.02806 seconds
Time After: 0.02819 seconds
Time Before: 0.03021 seconds
Time After: 0.03170 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=142419'
Time Before: 0.04576 seconds
Time After: 0.04602 seconds
Page generated in 0.044768095016479 seconds with 9 queries, spending 0.0082132816314697 doing MySQL queries and 0.03655481338501 doing PHP things.
