Time Before: 0.00538 seconds
Time After: 0.00935 seconds
Time Taken: 0.00397 seconds
Time Before: 0.00944 seconds
Time After: 0.01007 seconds
Time Taken: 0.00063 seconds
Time Before: 0.01034 seconds
Time After: 0.01055 seconds
Time Before: 0.01147 seconds
Time After: 0.01425 seconds
Time Taken: 0.00278 seconds
Time Before: 0.01062 seconds
Time After: 0.01930 seconds
Time Taken: 0.00868 seconds
Time Before: 0.02438 seconds
Time After: 0.02479 seconds
Time Before: 0.02788 seconds
Time After: 0.02999 seconds
Time Taken: 0.00212 seconds
Time Before: 0.02367 seconds
Time After: 0.03027 seconds
Time Taken: 0.00659 seconds
Time Before: 0.04403 seconds
Time After: 0.04420 seconds
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"11.30,\";s:9:\"lastcheck\";i:1788949430;}', 1)
Time Before: 0.05231 seconds
Time After: 0.05291 seconds
Time Taken: 0.00059 seconds
Memory Before: 3,439.656 KB
Memory After: 3,439.906 KB
Memory Used: 0.250 KB
Time Before: 0.06344 seconds
Time After: 0.06543 seconds
Time Taken: 0.00198 seconds
Memory Before: 3,526.469 KB
Memory After: 3,527.063 KB
End call of global.php: 0.068186044692993
Time Before: 0.07335 seconds
Time After: 0.07356 seconds
Memory Before: 4,164.406 KB
Memory After: 4,164.836 KB
Time Before: 0.07657 seconds
Time After: 0.07802 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
SET lastactivity = 1788949430, location = '/forums/private.php?do=newpm&explain=1&u=142423', badlocation = 1
Time Before: 0.09510 seconds
Time After: 0.09536 seconds
Memory Before: 4,920.063 KB
Memory After: 4,920.273 KB
Page generated in 0.09396505355835 seconds with 10 queries, spending 0.010791301727295 doing MySQL queries and 0.083173751831055 doing PHP things.
