Time Before: 0.00151 seconds
Time After: 0.00206 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00213 seconds
Time After: 0.00268 seconds
Time Before: 0.00289 seconds
Time After: 0.00299 seconds
Time Before: 0.00367 seconds
Time After: 0.00644 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00304 seconds
Time After: 0.00981 seconds
Time Taken: 0.00677 seconds
Time Before: 0.01151 seconds
Time After: 0.01186 seconds
Time Before: 0.01434 seconds
Time After: 0.01572 seconds
Time Taken: 0.00139 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01097 seconds
Time After: 0.01590 seconds
Time Taken: 0.00493 seconds
Memory After: 2,261.703 KB
Time Before: 0.02095 seconds
Time After: 0.02113 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02303 seconds
Time After: 0.02426 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.02695 seconds
Time After: 0.02714 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.02923 seconds
Time After: 0.03069 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=142437', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04323 seconds
Time After: 0.04356 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
