Time Before: 0.00207 seconds
Time After: 0.00283 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00294 seconds
Time After: 0.00350 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00378 seconds
Time After: 0.00396 seconds
Time Before: 0.00495 seconds
Time After: 0.00767 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00404 seconds
Time After: 0.01246 seconds
Time Taken: 0.00842 seconds
Time Before: 0.01460 seconds
Time After: 0.01478 seconds
Time Before: 0.01612 seconds
Time After: 0.01756 seconds
Time Before: 0.01390 seconds
Time After: 0.01781 seconds
Time Taken: 0.00391 seconds
Time Before: 0.02505 seconds
Time After: 0.02517 seconds
Time Before: 0.02723 seconds
Time After: 0.02880 seconds
Time Taken: 0.00157 seconds
End call of global.php: 0.030647039413452
Time Before: 0.03184 seconds
Time After: 0.03198 seconds
Time Before: 0.03418 seconds
Time After: 0.03563 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=142452', badlocation = 1
Time Before: 0.05020 seconds
Time After: 0.05048 seconds
Page generated in 0.049292087554932 seconds with 9 queries, spending 0.0086264610290527 doing MySQL queries and 0.040665626525879 doing PHP things.
