Time Before: 0.01315 seconds
Time After: 0.01670 seconds
Time Taken: 0.00354 seconds
Time Before: 0.01678 seconds
Time After: 0.01721 seconds
Time Before: 0.01749 seconds
Time After: 0.01762 seconds
Time Before: 0.01850 seconds
Time After: 0.02124 seconds
Time Taken: 0.00274 seconds
Time Before: 0.01769 seconds
Time After: 0.02518 seconds
Time Taken: 0.00749 seconds
Time Before: 0.03058 seconds
Time After: 0.03082 seconds
Time Before: 0.03371 seconds
Time After: 0.03495 seconds
Time Before: 0.02994 seconds
Time After: 0.03515 seconds
Time Taken: 0.00521 seconds
Time Before: 0.05354 seconds
Time After: 0.05369 seconds
Time Before: 0.06385 seconds
Time After: 0.06510 seconds
End call of global.php: 0.067990064620972
Time Before: 0.07218 seconds
Time After: 0.07233 seconds
Time Before: 0.07452 seconds
Time After: 0.07596 seconds
SET lastactivity = 1785408472, location = '/forums/private.php?do=newpm&explain=1&u=142538', badlocation = 1
Time Before: 0.09320 seconds
Time After: 0.09404 seconds
Time Taken: 0.00084 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.091915130615234 seconds with 9 queries, spending 0.0085940361022949 doing MySQL queries and 0.083321094512939 doing PHP things.
