Time Before: 0.00417 seconds
Time After: 0.00555 seconds
Time Taken: 0.00137 seconds
Time Before: 0.00562 seconds
Time After: 0.00611 seconds
Time Before: 0.00637 seconds
Time After: 0.00657 seconds
Time Before: 0.00751 seconds
Time After: 0.01072 seconds
Time Taken: 0.00321 seconds
Time Before: 0.00669 seconds
Time After: 0.01417 seconds
Time Taken: 0.00748 seconds
Time Before: 0.01642 seconds
Time After: 0.01685 seconds
Time Before: 0.01933 seconds
Time After: 0.02067 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01573 seconds
Time After: 0.02094 seconds
Time Taken: 0.00521 seconds
Time Before: 0.02934 seconds
Time After: 0.02952 seconds
Time Before: 0.03258 seconds
Time After: 0.03395 seconds
End call of global.php: 0.036707878112793
Time Before: 0.03846 seconds
Time After: 0.03866 seconds
Time Before: 0.04160 seconds
Time After: 0.04311 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=142593'
Time Before: 0.06083 seconds
Time After: 0.06116 seconds
Page generated in 0.059835910797119 seconds with 9 queries, spending 0.0092532634735107 doing MySQL queries and 0.050582647323608 doing PHP things.
