Time Before: 0.00147 seconds
Time After: 0.00192 seconds
Time Before: 0.00198 seconds
Time After: 0.00243 seconds
Time Before: 0.00267 seconds
Time After: 0.00282 seconds
Time Before: 0.00379 seconds
Time After: 0.00605 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00290 seconds
Time After: 0.01069 seconds
Time Taken: 0.00779 seconds
Time Before: 0.01272 seconds
Time After: 0.01316 seconds
Time Before: 0.01657 seconds
Time After: 0.01780 seconds
Time Before: 0.01197 seconds
Time After: 0.01804 seconds
Time Taken: 0.00607 seconds
Time Before: 0.02531 seconds
Time After: 0.02546 seconds
Time Before: 0.02765 seconds
Time After: 0.02894 seconds
Time Before: 0.03200 seconds
Time After: 0.03218 seconds
Time Before: 0.03431 seconds
Time After: 0.03576 seconds
UPDATE session SET lastactivity = 1772863005, location = '/forums/private.php?do=newpm&explain=1&u=142657', badlocation = 1 WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.04812 seconds
Time After: 0.04848 seconds
