Time Before: 0.01301 seconds
Time After: 0.01752 seconds
Time Taken: 0.00451 seconds
Time Before: 0.01762 seconds
Time After: 0.01823 seconds
Time Taken: 0.00061 seconds
Time Before: 0.01856 seconds
Time After: 0.01871 seconds
Time Before: 0.01970 seconds
Time After: 0.02258 seconds
Time Taken: 0.00289 seconds
Time Before: 0.01880 seconds
Time After: 0.02760 seconds
Time Taken: 0.00880 seconds
Time Before: 0.03176 seconds
Time After: 0.03198 seconds
Time Before: 0.03373 seconds
Time After: 0.03493 seconds
Time Before: 0.03091 seconds
Time After: 0.03523 seconds
Time Taken: 0.00432 seconds
Memory After: 2,885.227 KB
Memory Used: 132.898 KB
Time Before: 0.06374 seconds
Time After: 0.06389 seconds
Memory Before: 3,438.344 KB
Memory After: 3,438.859 KB
Time Before: 0.07167 seconds
Time After: 0.07302 seconds
Time Taken: 0.00135 seconds
Memory Before: 3,526.039 KB
Memory After: 3,526.633 KB
Time Before: 0.07822 seconds
Time After: 0.07840 seconds
Memory Before: 4,163.938 KB
Memory After: 4,164.367 KB
Time Before: 0.08151 seconds
Time After: 0.08297 seconds
Memory Before: 4,445.500 KB
Memory After: 4,447.188 KB
UPDATE session SET lastactivity = 1776458473, location = '/forums/private.php?do=newpm&explain=1&u=142693' WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.10053 seconds
Time After: 0.11652 seconds
Time Taken: 0.01599 seconds
Memory Before: 4,911.156 KB
Memory After: 4,911.383 KB
