Time Before: 0.00163 seconds
Time After: 0.00214 seconds
Time Before: 0.00224 seconds
Time After: 0.00267 seconds
Time Before: 0.00295 seconds
Time After: 0.00309 seconds
Time Before: 0.00381 seconds
Time After: 0.00606 seconds
Time Taken: 0.00225 seconds
Time Before: 0.00315 seconds
Time After: 0.01145 seconds
Time Taken: 0.00830 seconds
Time Before: 0.01354 seconds
Time After: 0.01392 seconds
Time Before: 0.01574 seconds
Time After: 0.01703 seconds
Time Before: 0.01301 seconds
Time After: 0.01720 seconds
Time Taken: 0.00419 seconds
Time Before: 0.02294 seconds
Time After: 0.02308 seconds
Time Before: 0.02538 seconds
Time After: 0.02661 seconds
End call of global.php: 0.028321981430054
Time Before: 0.02932 seconds
Time After: 0.02946 seconds
Time Before: 0.03151 seconds
Time After: 0.03294 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=142719'
Time Before: 0.04575 seconds
Time After: 0.04607 seconds
Page generated in 0.044754028320312 seconds with 9 queries, spending 0.0077636241912842 doing MySQL queries and 0.036990404129028 doing PHP things.
