Time Before: 0.00204 seconds
Time After: 0.00262 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00272 seconds
Time After: 0.00367 seconds
Time Taken: 0.00095 seconds
Time Before: 0.00428 seconds
Time After: 0.00469 seconds
Time Before: 0.00536 seconds
Time After: 0.00796 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00474 seconds
Time After: 0.01182 seconds
Time Taken: 0.00708 seconds
Time Before: 0.01378 seconds
Time After: 0.01419 seconds
Time Before: 0.01681 seconds
Time After: 0.01802 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01313 seconds
Time After: 0.01820 seconds
Time Taken: 0.00507 seconds
Memory After: 2,261.820 KB
Time Before: 0.02481 seconds
Time After: 0.02503 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02701 seconds
Time After: 0.02825 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.02991795539856
Time Before: 0.03169 seconds
Time After: 0.03185 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03415 seconds
Time After: 0.03624 seconds
Time Taken: 0.00209 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788920265, location = '/forums/private.php?do=newpm&explain=1&u=142730'
Time Before: 0.05186 seconds
Time After: 0.05224 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.050930023193359 seconds with 9 queries, spending 0.0096602439880371 doing MySQL queries and 0.041269779205322 doing PHP things.
