Time Before: 0.01069 seconds
Time After: 0.01465 seconds
Time Taken: 0.00396 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.01472 seconds
Time After: 0.01514 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.01536 seconds
Time After: 0.01566 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.01648 seconds
Time After: 0.01913 seconds
Time Taken: 0.00265 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.01572 seconds
Time After: 0.02261 seconds
Time Taken: 0.00689 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.02854 seconds
Time After: 0.02873 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.03107 seconds
Time After: 0.03224 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.02786 seconds
Time After: 0.03245 seconds
Time Taken: 0.00459 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.05637 seconds
Time After: 0.05651 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.10050 seconds
Time After: 0.10172 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.12225 seconds
Time After: 0.12242 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.12782 seconds
Time After: 0.12923 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1773106741, location = '/forums/private.php?do=newpm&explain=1&u=142734', badlocation = 1 WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.15538 seconds
Time After: 0.15577 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
