Time Before: 0.00209 seconds
Time After: 0.00274 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00283 seconds
Time After: 0.00332 seconds
Time Before: 0.00356 seconds
Time After: 0.00381 seconds
Time Before: 0.00466 seconds
Time After: 0.00676 seconds
Time Taken: 0.00210 seconds
Time Before: 0.00389 seconds
Time After: 0.01069 seconds
Time Taken: 0.00680 seconds
Time Before: 0.01265 seconds
Time After: 0.01321 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01597 seconds
Time After: 0.01716 seconds
Time Before: 0.01198 seconds
Time After: 0.01734 seconds
Time Taken: 0.00537 seconds
Time Before: 0.02352 seconds
Time After: 0.02366 seconds
Time Before: 0.02620 seconds
Time After: 0.02780 seconds
Time Taken: 0.00160 seconds
End call of global.php: 0.030550003051758
Time Before: 0.03240 seconds
Time After: 0.03254 seconds
Time Before: 0.03543 seconds
Time After: 0.03695 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1782910860, location = '/forums/private.php?do=newpm&explain=1&u=142741', badlocation = 1
Time Before: 0.04964 seconds
Time After: 0.05000 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
Page generated in 0.048742055892944 seconds with 9 queries, spending 0.0083608627319336 doing MySQL queries and 0.040381193161011 doing PHP things.
