Time Before: 0.00230 seconds
Time After: 0.00295 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00308 seconds
Time After: 0.00351 seconds
Time Before: 0.00374 seconds
Time After: 0.00391 seconds
Time Before: 0.00471 seconds
Time After: 0.00737 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00399 seconds
Time After: 0.01081 seconds
Time Taken: 0.00682 seconds
Time Before: 0.01284 seconds
Time After: 0.01326 seconds
Time Before: 0.01589 seconds
Time After: 0.01714 seconds
Time Before: 0.01207 seconds
Time After: 0.01734 seconds
Time Taken: 0.00527 seconds
Time Before: 0.02434 seconds
Time After: 0.02451 seconds
Time Before: 0.02654 seconds
Time After: 0.02792 seconds
Time Taken: 0.00138 seconds
End call of global.php: 0.029587030410767
Time Before: 0.03072 seconds
Time After: 0.03088 seconds
Time Before: 0.03347 seconds
Time After: 0.03496 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=142767'
Time Before: 0.05347 seconds
Time After: 0.05373 seconds
Page generated in 0.052026987075806 seconds with 9 queries, spending 0.0084104537963867 doing MySQL queries and 0.043616533279419 doing PHP things.
