Time Before: 0.01093 seconds
Time After: 0.01516 seconds
Time Taken: 0.00423 seconds
Time Before: 0.01530 seconds
Time After: 0.01589 seconds
Time Taken: 0.00059 seconds
Time Before: 0.01614 seconds
Time After: 0.01631 seconds
Time Before: 0.01717 seconds
Time After: 0.02068 seconds
Time Taken: 0.00350 seconds
Time Before: 0.01639 seconds
Time After: 0.02532 seconds
Time Taken: 0.00893 seconds
Time Before: 0.03081 seconds
Time After: 0.03119 seconds
Time Before: 0.03390 seconds
Time After: 0.03512 seconds
Time Before: 0.03015 seconds
Time After: 0.03533 seconds
Time Taken: 0.00518 seconds
Time Before: 0.05553 seconds
Time After: 0.05570 seconds
Time Before: 0.08991 seconds
Time After: 0.09119 seconds
Time Before: 0.09924 seconds
Time After: 0.09946 seconds
Time Before: 0.10182 seconds
Time After: 0.10330 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=142829', badlocation = 1 WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.12000 seconds
Time After: 0.12029 seconds
