Time Before: 0.01530 seconds
Time After: 0.02571 seconds
Time Taken: 0.01042 seconds
Time Before: 0.02588 seconds
Time After: 0.02629 seconds
Time Before: 0.02652 seconds
Time After: 0.02665 seconds
Time Before: 0.02762 seconds
Time After: 0.03022 seconds
Time Taken: 0.00260 seconds
Time Before: 0.02673 seconds
Time After: 0.03431 seconds
Time Taken: 0.00758 seconds
Time Before: 0.04457 seconds
Time After: 0.04509 seconds
Time Before: 0.04827 seconds
Time After: 0.04946 seconds
Time Before: 0.04390 seconds
Time After: 0.04966 seconds
Time Taken: 0.00576 seconds
Time Before: 0.08697 seconds
Time After: 0.08710 seconds
Time Before: 0.10272 seconds
Time After: 0.10400 seconds
End call of global.php: 0.10591888427734
Time Before: 0.11017 seconds
Time After: 0.11060 seconds
Time Before: 0.11364 seconds
Time After: 0.11508 seconds
SET lastactivity = 1782902705, location = '/forums/private.php?do=newpm&explain=1&u=142852'
Time Before: 0.13443 seconds
Time After: 0.13471 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
Page generated in 0.1333589553833 seconds with 9 queries, spending 0.0084073543548584 doing MySQL queries and 0.12495160102844 doing PHP things.
