Time Before: 0.01245 seconds
Time After: 0.01783 seconds
Time Taken: 0.00537 seconds
Time Before: 0.01792 seconds
Time After: 0.01830 seconds
Time Before: 0.01851 seconds
Time After: 0.01863 seconds
Time Before: 0.01937 seconds
Time After: 0.02208 seconds
Time Taken: 0.00271 seconds
Time Before: 0.01869 seconds
Time After: 0.02633 seconds
Time Taken: 0.00764 seconds
Time Before: 0.03247 seconds
Time After: 0.03284 seconds
Time Before: 0.03535 seconds
Time After: 0.03661 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03184 seconds
Time After: 0.03683 seconds
Time Taken: 0.00499 seconds
Memory After: 2,261.703 KB
Time Before: 0.05121 seconds
Time After: 0.05133 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06303 seconds
Time After: 0.06429 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.066629886627197
Time Before: 0.07372 seconds
Time After: 0.07393 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07665 seconds
Time After: 0.07810 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=142914'
Time Before: 0.09560 seconds
Time After: 0.09584 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.094482898712158 seconds with 9 queries, spending 0.0081369876861572 doing MySQL queries and 0.086345911026001 doing PHP things.
