Time Before: 0.01145 seconds
Time After: 0.01617 seconds
Time Taken: 0.00472 seconds
Time Before: 0.01624 seconds
Time After: 0.01667 seconds
Time Before: 0.01692 seconds
Time After: 0.01706 seconds
Time Before: 0.01785 seconds
Time After: 0.02042 seconds
Time Taken: 0.00257 seconds
Time Before: 0.01714 seconds
Time After: 0.02493 seconds
Time Taken: 0.00779 seconds
Time Before: 0.03231 seconds
Time After: 0.03275 seconds
Time Before: 0.03524 seconds
Time After: 0.03647 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03161 seconds
Time After: 0.03668 seconds
Time Taken: 0.00507 seconds
Memory After: 2,261.820 KB
Time Before: 0.05812 seconds
Time After: 0.05828 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.07083 seconds
Time After: 0.07206 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.074802875518799
Time Before: 0.08105 seconds
Time After: 0.08119 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.08373 seconds
Time After: 0.08541 seconds
Time Taken: 0.00169 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789055696, location = '/forums/private.php?do=newpm&explain=1&u=142974'
Time Before: 0.10302 seconds
Time After: 0.10337 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.10181903839111 seconds with 9 queries, spending 0.0083804130554199 doing MySQL queries and 0.093438625335693 doing PHP things.
