Time Before: 0.01402 seconds
Time After: 0.01883 seconds
Time Taken: 0.00481 seconds
Time Before: 0.01893 seconds
Time After: 0.01959 seconds
Time Taken: 0.00066 seconds
Time Before: 0.01991 seconds
Time After: 0.02008 seconds
Time Before: 0.02087 seconds
Time After: 0.02350 seconds
Time Taken: 0.00263 seconds
Time Before: 0.02015 seconds
Time After: 0.02806 seconds
Time Taken: 0.00791 seconds
Time Before: 0.03739 seconds
Time After: 0.03782 seconds
Time Before: 0.04040 seconds
Time After: 0.04166 seconds
Time Before: 0.03668 seconds
Time After: 0.04194 seconds
Time Taken: 0.00527 seconds
Time Before: 0.06811 seconds
Time After: 0.06828 seconds
Time Before: 0.08145 seconds
Time After: 0.08271 seconds
Time Before: 0.09120 seconds
Time After: 0.09137 seconds
Time Before: 0.09402 seconds
Time After: 0.09554 seconds
Time Taken: 0.00152 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=143009', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.11201 seconds
Time After: 0.11235 seconds
